B
bob
Guest
Tippie said:Beautiful work there Bob.
You really need to adjust the offset for different tracks?
Hi Tippie,
I won't be altering the offset for different tracks, the reason I've gone for adjustable yokes is simply so I can optimise the trail. Onced I've established the best setting I'll leave it where it is. At the moment I've got a lot of trail, this is because I've got a set of Spondon yokes of the type fitted to the Slater TT F500s. A 500 would be flat out for extended periods on the Island and apparently would get quite lively on some of the bumpier sections, hence the Spondon yokes. I have a feeling that an offset about halfway between stock and the Spondons will do the job but I didn't want to go the expense of having some trick yokes made only to find they didn't do the task properly. I had to have some yokes made for the 38mm forks I'm fitting so it seemed like a good opportunity to get the front end geometry sorted, the adjustability also allows me to experiment with dropping or raising the forks in the yokes.
Bob
