Fully rebuilt by Red for sure means it has run before. What plugs are used and have you changed them? I had several times the issue that cold starting with to much choke killed spark plugs. mostly just one, but who knows.Hi needing some help have a 750sf2 been sitting for 4 months previously fully rebuilt by Redax , new battery but no spark is fitted with a Sachse ignition have been all over the wiring, checked fuses, it's getting fuel wet plugs just no spark all input appreciated
Checking earths new plugs tomorrow ( Bosch in case it's dodgy NGK's )Tried new plugs, high-tension plug leads connecting plug caps. If both don't spark, that's a good indicator of a common issue. Make sure your earths are nice and tight.
Thanks Rob on to that tomorrow great informationI'm not familiar with the Sasche unit but believe it has a test facility. Turning the selector switch to 0 fires the plugs continuously with ignition on -
Test Mode
The ignition box features a test mode. This mode make the spark plug(s) fire continuously
without the engine running. This tests the power supply, wiring, coils and the ignition box.
However, it does not test the pickup. For a working ignition test mode has to succeed.
To use test mode, unscrew the spark plug(s) and place them back into the plug caps,
so the spark can be observed. Then switch the 10-way hex switch on the side of the box
into position ’0’. Then turn on the ignition. You should get a continuous spark. If that’s
not what’s happening, check the voltage between ground (pin 2) and pin 8 if it reads 12 V.
Sometimes it is required to turn the ignition off and on again to engage test mode.
I have changed them a couple of times previously with the same complaint ( failed plugs NGK's ) I did renew the earth connection to the wiring as it just didn't feel good, charging the brand new battery overnight and I'll put all the great advice to work tomorrowFully rebuilt by Red for sure means it has run before. What plugs are used and have you changed them? I had several times the issue that cold starting with to much choke killed spark plugs. mostly just one, but who knows.
Earth is a very good hint, had that with a cable coming lose under the regulator... Sometimes - even if well experienced - crimping connections fail. Had that also when I hooked up my DMC 30 years ago. First time I just hooked it up with long cables and bike was instantly running. Then I shortened the cables and obviously the crimping of the earth cable wasn't good. Bike did not fire up. searched for two full hours, not finding the fault. Braught the bike to Uwe Witt's workshop and they found and fixed it...
If you have to change plugs often due to cold start fooling, you might want to consider a change on your start-up procedure and/or check your float hights and float valves (later one to close completely once the float is filled to the right level), sync the carbs and especially the choke plungers (they need to be equally high, moving at the same time and close completely when you close choke, please). Choke plungers synchronization is mostly disregarded but makes a hughe difference if out or correct.I have changed them a couple of times previously with the same complaint ( failed plugs NGK's ) I did renew the earth connection to the wiring as it just didn't feel good, charging the brand new battery overnight and I'll put all the great advice to work tomorrow
Good to hear.Thanks everyone for your great advice the problem was a dodgy earth wire from the battery to the wiring harness, again thanks brains trust for all your input cheers Chris
A couple is two. Are the others all broken?A couple of the rides
