piranha-bro2
- Melbourne
Hoping some of you elec boffins can offer some help here. Drivers (right) side window on the (right-hand-drive) Skoda Octavia decided to stop in the down pos (mid-winter, Melbourne!), with an audible click when the switch is pulled/pushed for up/down ... click sounds a lot like a relay in the mechanism. After a minute or two the window will move up half an inch from fully down, then the clicking is all you get each time the switch is activated.
Been driving round with opaque plastic taped to the friggin window and a square of cellophane in the middle to enable visibility of vehicles coming from the right. Really good fun.
So ... finally got the time to remove the door panel, pulled off the motor off and away from the window regulator splined thingy. Plugged it all in and the motor turned in either direction with no load. Can move the window up or down in the sliders by hand - can turn the spline by hand to wind it down but twice as hard going up and needs a little help by pushing the glass (gravity, I presume). Sprayed silicone in runners to be sure. Pretty sure resistance in the runners isn't the prob. The window regulator wires all seem fine and there is no clacking that's symptomatic of reg wires all tangled and loose.
Was about to give it a rest for the day when I checked the motor unloaded (not connected to the window) again and it turned for a few seconds and then stopped - only the 'relay' click. Multimeter seems to show 12ish volts at the thick wires that would appear to feed the motor directly (there are a LOT of wires in that switch panel: 4 x windows, central locking, window anti-pinch sensors etc) - window motor are the only thick wires, the rest are thin CanBus type skinny wires. Symptoms speak to me of insufficient current, but if it were a starter motor it could also be dodgy brushes, could it not?
Question for the panel of experts: how do I determine if ... a) the motor is the fault? or b) the motor is good but the voltage is getting lost somewhere? or c) how many volts should be getting to the motor?
I know it's not a Skoda forum but I reckon I'm more likely to get someone here who knows about such things than I will on the Skoda forums (although Briskoda is pretty bloody good ... the Oz version seems more interested in mag wheel and colour options!)
If you have only smart-arse answers, please stay off - I'm just not in the fukken mood.
