otis v11
- New Zealand
Running a Redax/Lx/Ignitech 300 watt alternator& charging system on my old 3c and has stopped charging.Anyone had this problem and whats the fix.
Nothing special about the Redax system. Alternator-regulator/rectifier-battery. All provided apart from battery of course. All new wiring.Could try connecting the rectifier directly to the battery , by-passing the harness , see if it starts charging then ......... if the harness is still original , the parts of it which haven`t been replaced with the new ignition system will be knocking on for 50 years old now .
Dunno anything about the Redax / Ignitech system , but as Paul points out above , in the normal course of things you should only looking at the state of health of the alternator , the rectifier / regulator , and the connections between those two and the battery .
most likely the regulator has fried, nothing special about them, majority of modern bikes have 3 phase charging systemsRunning a Redax/Lx/Ignitech 300 watt alternator& charging system on my old 3c and has stopped charging.Anyone had this problem and whats the fix.
talk to Aprilla owners, Richard was telling me when ever you talk to another Aprilla owner first question is how many stators have you gone throughNote: series 1 triple air cooled stator, series 2 triple runs in oil.
Harley Sportsters too, a lot of girls have to take them to a dealer because the stator is buried insidetalk to Aprilla owners, Richard was telling me when ever you talk to another Aprilla owner first question is how many stators have you gone through
To true. After the stator on my 2004 RSV was kaput, I changed the regulator to a Compu-Fire 55402. This regulates voltage and with this protects the alternator and leads to thermal relief:talk to Aprilla owners, Richard was telling me when ever you talk to another Aprilla owner first question is how many stators have you gone through
