poffer said:
Of course, if you want to have a go at making sought after spares for Laverdas, go for it. Nobody (apart from Red) makes engineering parts for Laverdas - valves yes, heads no. If you think there's money in it - good luck making a frame/crankcase/wheel/head/speedo/revo etc. etc. etc.
Really think so Pete?
OCT, Wagner, H?rter and Gijs v. Dijk can supply many bits and pieces reproduced long after the factory went bust. These firms have commissioned enormous batches in the past to keep hundreds of bikes on the roads world wide. The parts range from valves and guides, valve springs as well as numerous other unique springs, pistons, big-end bearings, swingarm bearings, oil pumps, cam bearings, cam and primary chain tensioners, starter clutches, starter motors, brake, clutch and throttle cables, speedo and tach drive cables, rubbery odds and sods. Many of these parts are manufactured by
OE suppliers, mainly small outfits located throughout northern Italy. Apart from the special bits, these firms also hold an enormous stock of generic parts such as chains, bearings, etc, as well as tons of NOS items (including twin heads if you happen to need one!) next to even more tons of good S/H spares(frames, tanks, side panels, mudguards, forks, etc, etc.
Next on the OCT agenda will be gearbox shafts and gears for various hard-to-get types. Unfortunately, it is becoming increasingly difficult to have parts made at competitive prices, considering the small batch sizes that are the norm these days, and no, there's not much money in it either!
It's not the large bits that are needed, it's the consumables, so no real need to break perfectly good, restorable bikes. Think about it next time you order a set of cush drive rubbers for your clutch...
