Just read this thread, Rob and especially Cam has the solution to the "conundrum" of rising volts on rising load, its the sense wire operation on SH530 doing what is was designed to do, been covered so many times in the past decades. As the bike harness wiring/connectors and switches age, IR ( current times resistance equals voltage ), so as the I increases in the wiring the voltage drops increase in the harness and where the sense wire is terminated the voltage drop is sensed and converted to a voltage rise in the RR output, does this in proportion to the formula of IR, ie nominal charged battery float of some 14,2V ( 13,8V is not good enough at Battery terminals point of measure ) to 14,4V. at say the incorrect 16.1V overvoltage, you had some 2.0V of losses in the wiring system. Yikes Vince this was not difficult to diagnose and cure, easy most fix was to connect RR sense wire to Battery Positive terminal direct, allowing for the slow discharge at some 1 to 2mA ( 0,001 or 0,002 Amps ) of the direct sense connect... Much ado about nothing... a wry smile here. Hope you have sorted the RR on your bike by now. j.
