I have Ross Racing rings to put in a Laverda. Ok cylinders bored @ 8/100ths. Rings 2 & top pregapped gapped@ 33mm. Ok the oil expander ring edge when placed in piston will stick out slightly from the circumference of the piston. So my guess is it also is Ok. Rails are on the inside lip step...So I guess it is preset? 2nd & top ring are @ 33mm gap but the rails when on the oil expander ring have a much larger gap. Called Ross they said it should be Ok. Just want to be sure...
