Oil lines on sfc1000/RGS etc.
http://cgi.ebay.co.uk/Laverda-Goodridge-Oil-Hoses-/130541670299?pt=UK_Motorcycle_Parts&hash=item1e64e3cf9b
breganzane said:
While you're at it, at the cooler end, get 180deg fittings so the cooler can be properly mounted with the fittings at the top (so it doesn't drain).  Laverda never did that right.
Not so sure about that, Steve.
When disconnecting the cooler, only a little oil drains from it.  The cooler needs to be stood on one of its' ends to drain it further, so I assume the feed tubes reach almost to the top of the cooler on the inside and it fills from there.
I'd say they don't fit and RGS series bike, as they need propper fittings.
fleaybay is often as it is often said also here, way too expensice. I can have a similar set made for less.
Jacques.
