michipons
- Palma de Mallorca
Hi!
I started with a common problem which I could find some old topics in the forum regarding the oil pump. Basically when assembling the shaft it doesn't rotate freely, I can rotate it with the hand, but is not smooth. I have checked everything, the shaft is spinning smooth in the engine case, also in the oil pump body separately, the teeth wheels are also moving freely, but when I assembly everything initially the shaft finds a step and won't come in, but when putting it with loose screws it goes in but as soon as I try to tight 2 of them it goes hard again, I have tried to tap it to find the sweet spot and all that that I read in the forum. (I started the bike with this pump, and it was running, so maybe is not sooo bad)
Anyway, after I analyzed the thing closely, I started to see some modifications in the pump, like a bit limed in the side to make it fit in the engine case, a handmade key... and looking carefully, the screw holes in the pump body don't fit PERFECTLY with the engine threads, so I have the theory that the pump was changed and that this one is not the original one but an adapted one... What do you think? does it corresponds to an SF3 oil pump? when installing it, it also doesn't fit to the shape in the engine!
If that is the case, I will continue the thread asking about where to find the original one or an aftermarket that will fit perfectly!
If I don't find any, a possible solutions would be to make the oil pump body screw holes a bit wider, to give the pump enough play to be adjusted so the shaft is not dragging that much...
Regards,
Miguel
Regards,
Miguel
