Oil seal size rhs gear shift shaft 180 1200 Series 1
Shuggie
Scottish islands
I've measured the size of the aperture on my casing and I get 14 x 19 x 2 .
Can you knowledgeable guys tell me the size, the nearest seal I can get is 14 x 18 x 3
Cheers 🍻
No idea if it's correct, but I have added a large thin washer between the case and the lever, which helps hold my seal in.
Thanks guys, that explains why it's an odd size...I've got the inner M14 washer and the outer...anyone tell me the correct o ring size, please...I was thinking 13 id with a CSA of 3 to get it sealing well.
Cheers 🥂
There's a typo in the info provided by Paul. If you checked the parts list in the library you'd find it's an O ring - OR 3056 - which is 2.62x13.95mm
Cheers , you're a great guy to know...that's an imperial size ref BS113, I've just bought one for the sum of £1.45 posted rm48 😄👍
