The Countershaft sprocket oil seal (the one that's on the ouside of the shaft not internal??) on my SFC 1000 has been weeping for awhile so I decided to replace it. Simple job, pull the old one out, clean up the surfaces a bit, make sure there's no sharp edges or anything. Put the new one in (with a bit of oil on it) and away I go. Problem is - the new one doesn't appear to seal onto the steel spacer ring like the old one. There is a gap of about 0.5mm (by eye) between the I.D of the Oil seal and the O.D of the steel spacer, and I'm sure that the old Oil seal actually sealed against the steel spacer?? Mind you there was a bit of crap and stuff around the old seal and I didn't take that much notice! Understandably nervous, I went for a ride only for about 5kms, got home, pulled the sprocket off and it was bone dry there - not a sign of a leak.
Am I just being nervous about this or has anybody come across this before? Is there different seals from different manufacturers? (This new seal I think is part of a complete gasket set that was purchased from Wolfgang a number of years ago and is blue and yellow in colour - dims 45/60/7. The old oil seal is black in colour - dims 45/60/8) I will go for a longer ride this weekend - but if anybodys got any thoughts.........
Keith.
Keith.
