I decided to design a 2nd breather after monitoring the crankcase pressure on a 180 degree triple on my test bench, I set up a 0-10psi transducer installed in the dip stick hole and ran the engine
Having been involved in drag racing in the past where they use Vacuum pumps to scavenge the crankcase cavity to gain horsepower I was interested to see what was going on
You could watch the gauge on the software go crazy, up to 6 psi fluctuation depending on revs whereas do the same on a 120 and the needle barely moved
Is caused by those 2 pistons going up/down and the poor old middle piston trying to keep up so I machined up and installed a 2nd breather bolted to where the Starter motor should be and which has a Kawasaki 125cc 2 stroke Reed valve inside of it
Works really well
I doubt that anyone else has ever taken the time to set up and record the crank case pressure on a Laverda triple
Shit you do when trying to find power out of these old clunkers
