From Brook Henry of Vee Two Ducati:
"Roller Big Ends have been around in motorcycles for many years. They are also used in many of the late model 4 stroke Moto X engines. Many of these later engines do not have pressurized oil feed to the big end. They rely totally on oil mist and oil splash to supply oil feed to the big end.
Laverda Triples have never had a direct oil feed to their roller big ends. Again, they rely on what is called an oil slinger. This is a method of collecting oil and oil mist from what is floating around the crank cases. The oil is collected within a thin metal disc fixed to the side of the crank shaft and then directed into the big end assembly. There is no pressure or direct oil feed at all. Interestingly, Laverda crank shafts and big ends do huge milage before requiring any attention. As a comparison Ducati Bevel big ends do not do any where near the same milage before failing. The Laverda Tripple engine was one of the most reliable engines in endurance racing of that time. Interesting fact since they only rely on a splash and mist feed to the big end."
Link to entire article:
https://www.veetwo.com/Info/what-en...h-tqaxYR7mdFaBELvgPB8dMmSA7Z4OjAbRXmcovCus-9Y
