Eurocycleguy
- Chicagoland-USA
Working/learning on rebuilding Starter Clutch for 750. Clutch action is better only occasional catches, crunches and sparks flying out of clutch.
AND Then apparently the engine didn't start but the Starter Motor kept turning over and the Starter Clutch was engaged. Bang on starter Button, Pull Key out, $h!t gotten get the seat off! Wait get side panel off get to Solenoid! Crips! cable smoking
Undo nut on output terminal of solenoid $h!t that's hot!
So starter Clutch is still not right after rebuild with new parts Spring, Pegs (Plungers), Rollers all nicely lubed and riveted back together. Still chunks, clunks and spits sparks
And now I get to delve into the mysteries of the solenoid, not hard I know just another item on the list. Grrrrrrrrrrr
Rant done for now.
All Better.
Rant done for now.
