"I can perhaps understand why. Although it makes the bike wider I've always preferred the Spondon, and the swing arm pivoting in line with the gearbox sprocket, over the Harris frames et al."
I have to strongly disagree with that Manxmog, the chain line of the bike and the swing arm pivot is a critical element in the bikes handling, almost any bike you look at will have the top run of the chain kissing the swingarm when parked, lots have a plastic/rubber slipper to safeguard that swing arm, especially dirt bikes, look at the way a 630 or to a lesser extent 530 will notch the swing arm on a Lav twin or triple, this is because under hard acceleration the taught top line of the chain will tend to load the front suspension and prevent lift, the reare squat is also then controlled. Many "specials" ignore this to some degree, e.g. Gary Laurence (Jota/Norton featherbed) where not only is the chain about 50 mm clear of the top of the swing arm, but he also runs 19/47 gearing (on 18" rims), so it goes like shit of a shovel, but tops out early and must be wheelie prone (which he admits to and rates it as super performance not bad hadling/under gearing) The famous Mike Hailwood 500 Honda 4 (the Camel) didnt handle at all well in any frame (I witnessed 3 variants) because everything was correct, except the crankshaft rotated backwards to normal, that meant the rear wheel was constantly losing trcation, it made for great spectating as SMBH wrestled it without fear. when buidling a special the cranksahft centre height is also critical and again very often ignored or impossible to comply with if you dont do major frame surgery, as in NorVin. our Rotax engined Zane has precisely the correct crankshaft centre height and forward/rear positioning, plus the engine is tilted slightly to get the sprocket postion good as well, so Spondon with swing arm pivot concentric with the gearbox sprocket = CRAP. if you want constant chain tension AND correct sprocket height, take a look at Nessie, currently on sale in Italy for around £40,00, I would buy it for £15,000.
