If you were my Dad, I smother you with a pillow in yer sleep to get hold of those two! We have the same taste in bikes.Father and son out for 3 days.
Can't fail with that equipmentFather and son out for 3 days.
What odd noise? I’m intriguedRun-in and shakedown run for the Q. 300km of twisties on a clear and cold day through the mountains. Running beautifully ... save an odd noise at very random and occasional times - will investigate tomorrow. Pic 1: Maroondah Reservoir lookout . Pic 2: the infamous Reefton Spur - only one car between Marysville and down the other side of the Reefton - no cops either!! Super!
So am I!! Hopefully I can trace it tomorrow and it's nothing deep and seriousWhat odd noise? I’m intrigued
Noise is definitely motor related. Suspension felt fantastic today. Haven't touched it since I made a few small changes at The Island last December.Not exactly wet weather rubber Q. Pretty close to a slick. I put a cable tie on one of my rear shock shafts, occasionally sound might be something rubbing on big bumps. I am hoping to do a few test laps around my block tomorrow, my shocks are so much more complicated now with the harder springs but much less preload to get better sag.
Oh no, you don't want unspecified noises after disassembly/assembly, your ears have probably grown a lot! I'm keeping my fingers crossed that it's just a minor thing!So am I!! Hopefully I can trace it tomorrow and it's nothing deep and seriousI'll keep you posted.
Good ta see young fellaRun-in and shakedown run for the Q. 300km of twisties on a clear and cold day through the mountains. Running beautifully ... save an odd noise at very random and occasional times - will investigate tomorrow. Pic 1: Maroondah Reservoir lookout . Pic 2: the infamous Reefton Spur - only one car between Marysville and down the other side of the Reefton - no cops either!! Super!
He took a video of him overtaking me.Ariel manages to follow ?![]()
Port Erin?Nice day so decided to take the 100 Sport for a run, the first for awhile, so it took a bit of coaxing into life. Having warmed it up, I then remembered I hadn’t adjusted the clutch cable as intended. On the previous ride I had found the clutch wasn’t quite disengaging properly when pulling in the lever. So out with the spanners to slacken off the adjuster at the front of the engine and promptly burnt the inside of my forearm on the exhaust,
Having applied a liberal amount of cold water on the afflicted limb I did manage to complete the adjustment and at least the clutch is behaving now.
I would have let him ride the Guzzi.Father and son out for 3 days.
Takes a bit of getting used to.I would have let him ride the Guzzi.
Marnix
