Out and About on your Laverda.No bull,Just photos
Yeah, geez! Oil thread!!!
Yeah it’s a great oil, but a couple bikes I have run very hot, and in the Honda XR650L’s case, very hot and very small oil capacity. Full synthetic ester based 20w-50 is the only way for this machine. The RC30 engine is magnificent, but horrifically expensive should something go wrong, so it gets ester full synthetic 15w-40. Norton needs thick oil, non synthetic 20w-50, as does the Laverda.
Friend unearthed some old pictures from the past - my SF1 in spring 1981:
Your not wrong there - Thinking of putting a Don Pender TZ Replica on the Front
I went through two genuine TZ 4LS brakes on the front of my SF1. The first was pre-owned and quickly showed its age with hot spots where the alloy had started coming away from the cast-in drums. So I scored a brand new old stock one and laced that in - it actually went stright into the Boranni rim with (from memory) a bit cut from the spokes. It was a fantastic brake, good feel and power when it was running newish shoes, but eventually the same thing happened and it also became very grabby when cold if the shoes had a little wear.
I gave up and went to double Brembos. Maybe the Don Pender repros are less fragile - I be they're not cheap!! I always lusted after a big Fontana (or Grimeca?) as seen on the early 70s SFC factory bikes.
Fontana or Ceriani. 230mm.
Thanks for that info - Hub in the QLD Laverda Club Grew up with Don Pender and is still good friends with him.
I will ask Hub to speak to Don and see if he has got these problems sorted.
Don Pender is the Guru of Nortons - If you get a chance, check out his website
From Memory I think Hub said that they cost about $2,500. for a complete wheel + cables +Lever and Axle
Cheers Adam
Sounds good! I'd love to see one. If i'd been able to make mine reliable and long wearing I would definitely have been happy to keep it. Very light wheel, so big benefits in unsprung weight. Hub? What a great nickname for someone with break connections!
There not Laverda's but a few years ago I picked up a Parilla for a Mate and this is what was in his mates Shed.
87 is a famous number in Oz for Vincents, that was Eric Debenham's number. Saw his Norvin demolish the Inup at Amaroo Park back in the day. It was Superfast
