GregT
- Christchurch NZ
redax5 said:Hi Phil,
Clem, you could go to 83.0mm by using custom liners which I have in stock by the way.
The protruding part at the bottom you would run at 1.5mm wall thickness by machining down the outside diameter which would allow you to use a 1200 size counterbore in the top case.
Can get any piston you want made these days but I have 83.0mm x 13:1 pistons in stock.
Might be a bit large for normal street engine.
We intend to use these pistons towards the end of the year but first I have to modify a set of cases to a through rod design on the engine studs so we can increase the clamping force to contain the compression.
The bore size is not a big issue, the weak engine stud design is by far the biggest hurdle
Red
Are you talking case studs or barrel/head studs ? Is there a history of failure in this area ?
