P8 Caliper strip
philw
lincs
Hi all, the right side front brake Caliper on my 77 Jota is binding, and i'm going to attempt to strip it down and fit new pistons/seals etc. i'm led to believe its a twin bleed nipple Brembo P8 item, any useful tips and things to watch out for would be welcome, and can anyone recommend where to source the pistons and seal kit from in the UK please?...i'm anticipating bleeding the system once everything is refitted might be a challenge, i remember the last time i had a go at this on my old triple about 20 years ago and it didn't go well!
Thanks in advance.
Phil
If the nipples are stuck , don't give it that extra force, they are easily snapped off. Use heat and Loctite Freeze and release alternately...if you do snap one Paddy does a 7mm oversize one....first rate guy for help and parts, cheapest as well
