Painting the raised white Laverda lettering as it has yellowed?
Comen996
Walnut Creek, CA
is there a "correct" paint code?  Would one use a pen type ballpoint or a tiny touch up brush?  Or would you leave it as a touch of patina?  If the paint is perfect elsewhere, the yellowing sort of stands out. Hurt or help the value?  Or no effect. ?  Thx.
Wolfgang has new badges pretty cheap. I chose that route vs repaint mine this time on my Corsa. I have all the badges off off as I had the bodywork repainted. In the past I have used auto touchup paint or Testers paint used for model cars etc.  If the paint is flaking you need to scrape it off first and use  a wax degreaser first.
Just for info - the badges I sourced from Wolfgang were completely flat.  The petrol tank isn't - it's compound curve requires more than a simple bend.  Or use thicker double sided adhesive foam tape
Those badges bend pretty easily. They are some sort of soft alloy and will take the gentle curve of a fuel tank easily enough. If your fingers aren't strong enough to press it into shape, place it on an appropriately shaped former and tap it gently with a rubber hammer. Best to put it in a plastic bag so you don't get any dirty marks on it before trying to form it.
Easy to bend once, then they stress harden,
Best get the bend profile right first time.
Yes indeed, I suspect they're made of die-cast metal like Dinky toys (Zn, Al, Cu alloy) which work-hardens if you look at it sideways.
Probably showing my age with the Dinky toys reference.
Davo said:
Gotta be a pretty big plastic bag to fit the bike in  :o
:LOL: He only needs to put the tank in a bag.
You can get them here: http://www.ebay.com.au/itm/Bodybag-W-Arms-/272442486893?var=&hash=item3f6ed6706d:m:mUnudcvhZ--CZSzO_RCRjCw
Did these yesterday.
Curves in 2 directions, different each side.
Took only a few seconds to get the right profile, but got to get it right first time.
