Adventures in 750 rusty tank world
When putting the 750 back on the road, i had 4 tanks to choose from. 2 where decidedly rooted, one had really nice black paint, but was a bit rusty, and my old SF0 tank previously crashed by me, also a bit rusty.
I went with the black tank, and Will used evapo-rust to treat the inside. The job came up great, clean as a whistle. Unfortunately, what I didn't notice, until the tank fell off the front locating pins onto the motor, was that it had been pranged and badly repaired at the front, the locating hooks where about 15mm wider than they should have been.
Out with the oxy and a rachet strap, and the front of the tank was brought back in, unfortunately the paint was now fooked, the nylon strap mark is very evident across the top where it sank into the heated paint, and there is a crease in the metal at the top. Oh well. I dragged out my old 750 tank, still full of dents on the lh side, and thought, no probs, going to be covered by a tank bag anyway. Some grey primer, and some caustic solution to clean out the rust. I wasn't worried about the paint now. Tank came up clean, and pressed into service.
Got back from the run to Canowindra, and it was a bit down on power on some of the hills. Pulled the carb bowls, full of rust! WTF!
Brett advises me that all fuel can legally have up to 5% ethanol, and still be marketed as non ethanol. I think the way the caustic solution has etched the metal has opened it up to allowing agreesive rust. If i look down in the tank, its not too bad, but the roof is bad.
Evapo-rust says it leaves a protective coating. Maybe. I grabbed the repaired black tank, now been sitting on the shelf in my shed for 6 months at least, in a very wet and humid sydney summer, it looks ok.
Now the next twist. 12 months ago, evapo-rust guys (from NZ), sold the name to CRC. Not the same formula, but the product is advertised as the same. Price is the same. I don't know what the difference in the product is, waiting on a call back from the ozzy guy in mackay, QLD, who can supply me direct the original formula.
I will keep you posted.
So the question is, once you have etched the steel with caustic, short of lining it, (I hate tank liners), how do you stop modern fuels rusting up your tank.
