Hi Pauls, not sure where you are, RG6? By the bloke on your video I'm guessing your in the UK. What is he actually measuring? E10 fuel has 10% ethanol right? So he's saying it ranges from 7.5 down to 2.5% ethanol? So what is this bloke proving? What is going to "kill your engine"? There where claims originally that ethanol was abrasive and caused wear in injectors. I haven't seen that in Oz. We get our fuel from signapore, no refineries left here. 4 main types, 91, 94 E10, 95, 98. Brett tells me that legally they can sell non ethanol fuel with up to 5% of the stuff in it. (Government did a dodgy deal with producers).
I see a lot of carbon buildup on valves on bikes running 98. The worst was a 1200 Bonneville, could have sworn it was big end/ little end, turned out to be pistons hitting the carbon. Throttle bodies off, spray some three bond engine conditioner on the backs of the valves, turn motor over by hand to open the valves and squirt it in. Leave to soak, then an Italian tune up. Fixed.
750 with points, easy to set up for timing, it will run happily on 91 or 95. Triples running ignitech, (3c and 3cl), run well on 95, but needed the laptop to tweak the timing. The 6 plug 3cl needed a lot of trial and error, very custom curve, whereas the 3c , jota pistons, Ricky racer cams, used one of Reds curves, but needed to knock a couple of degrees out of it.
