As Alan, Steve. Also:
Definitely change the tyres - and also the wheel bearings, front and rear and in the sprocket carrier. It's just not worth not doing.
DEFINITELY a brake strip and clean - and re-rubber throughout (master cylinders and calipers). And change the brake hoses. The old ones will be stuffed - weak and swollen.
Check the head bearings. Drain and refill the forks. The rear shockers will most likely be stuffed - they leaked almost from Day One
. Not worth re-building, IMO - DAMHIK, but Grant may disagree. Get some new ones - plenty of advice which to chose, much depends on your budget.
The screen isn't fitting properly at the front. Dunno what's going on, but they do slip off their supports. Not serious - just don't leave it like that.
If the bike hasn't yet been crated, tell the shipping agent to be VERY careful with the indicators. They are vulnerable and hard/expensive to replace.
If I think of anything else, I'll say.
And congratulations!
Craig
P.s Don't forget to change the horn blades.
