phil37 said:Paul - I don't like the long length of steel exhaust pipe that goes into the head on the 750's - not good practice - I shrink a length (about 20mm) of aluminium tube into exhaust port and use a short flange - like on the triples. Maybe easier for you to put a shorter insert into yours to get extra protrusion of the flange. - regards - Phil
The intention is to get as much as possible of the exhaust heat into the header and out before it dissipates into the head. The first part of the header should have no contact to the head other than the sealing surface. Laverda used an even longer set-up on the 500 and 600 engines to help keep the exhaust valves and ports cooler... still not enough, as recent history has shown.
This has been discussed at length in specialist literature, similar lay-outs can be found on Manx Nortons and Matchless/AjS G50/7R where the headers are also fitted deep into the ports.
