Piston rings
Fitz
Cheshire UK
Any have a source for piston rings for SF750, 80.4mm Asso type 1.5mm, 2mm, 5mm, prefrer UK buyt Europe is OK. Andy Wagner cant get them until next year, need to keep my head occupied with rebuild
Hi Fitz, I got my 750 pistons and rings from Keith Nairn at Laverdascozia,
If Keithe doesn't have them, you could try South Wales Piston Services, https://www.southwalespistons.com/Services/Parts-Sales/parts-sales.html
They were recommended to me by a VMCC member, but not used them myself as I'd already bought pistons from Keith.
I'm sure ASSO piston rings are the same as that for an other Italian stallion the Fiat 126 Bis 700cc. Are you sure the oil ring is 5mm
If all you can get are one piece 5mm wide oil rings and you want something better, have a look at VW ring sets in the Grant or Hastings catalogues.
Some time back I found 3 piece - two thin rails and an expander - 5mm wide oil rings for an engine I did.
Can't remember now which supplier I used sorry. 80.4 is a VW oversize.
Hi Fitz, try the "King of Piston" in Italy:
http://www.thekingofpiston.com/index.php?lang=en
https://www.pistonshop.it/ricambi-motore/segmenti/
Ciao, Gert
30 years ago I went to Repco head office in Melbourne and they let me scour their entire stock inventory and I found a full set of rings in 80.4. I used a three-piece oil ring but ended up swapping them all out when i sourced genuine parts. But they were a perfect fit, good quality and quite inexpensive. That probably doesn't help you at all - 30 years later on the other side of the world! But does demonstrate there are loads of options out there.
Wolfgang is noted for having a specific Laverda Ring for yor needs.
He saved my 70 SF .
Piston to Bore clearance can be outta spec up to .050" clearance if you have aligned honed bores but Ring Gap has to be perfect within 0.002" thousands for that specific bore. Learn to file and fit an oversized ring for a particular parallel wall honed bore dia using the pistons you have ;o)
