Pits in chrome Staunchions
ghwallice
Ipswich
I have some staunchions with pitting in the chrome. Thankfully not on a Laverda, just on one of those junky old Ducati things.
As a temporary fix I've been told superglue is the go. What is the process? Clean with, say, contact cleaner, dab on superglue, let it dry, and then buff level/smooth with about a 2000 emery? Will it last?
Given all the advances in chemicals, I would have thought there was a better chemical to use. Is there?
Opinions appreciated.
Regards, Greg
Some how to instructions in a similar thread last year:-
https://www.laverdaforum.com/forum/index.php/topic,99111.msg425727.html#msg425727
PS - no idea if it is effective, just remembered reading about it...............
My guess is rust ridges have more effect than divots, ridges would tear a seal where a divot would let a bit of oil out. I stoned, oil stone not doped, the legs on my Pantah a few years before replacement and that slowed the leaks a lot
I understand superglue does not hold up in wet environment?
JB weld is better IMHO  (or any decent epoxy)
I have used scotch-brite on forks before, to feather the edges of a chip in the chrome caused by wear. The sharp edges of the chip were tearing the seal causing leaks. I was impressed how effective scotch-brite was but you've got to be careful not to over do it, you'll be down to the copper in no time.
Then I rotated to stanchion 90 degrees.
SimonR501 said:
I got multiple hits by googling 'Crocus Paper P2000'.
It's all over Fleabay!
https://www.ebay.co.uk/c/881338508
Never even bothered with a gogglebox search - always just buy it from hardware joints ... and Bunnings. Would have been handy finishing off my alu plug before polishing.
