I am trying another round of fork mods rather than sending them to Maxton's. I noticed they were pulsing a small amount when cruising and if I held the brake and bounced it the fork would go down at a steady pace but rebound very quickly and then bounce down and back. Looked to me like it lacked rebound control. With emulators fitted the only adjustment for the rebound is oil weight, it had 15wt the recommended by Race Tech and set at 140mm forks bottomed and emulators and springs out. I had some 15wt and 20 wt so I made a mix of these 50 x 50 to get 17.5wt and as I was losing 20mm of travel at the bottom it's now set at 190mm. It's easy to do a volume calc if needed to find what cc,s would equal upping the oil level in 10mm steps if needed to stop bottoming. The emulators are set as soft as I could get them and they stayed at that setting. Bouncing them now has the compression and rebound speeds very similar and at a steady pace. I like its feel, now all I need is for the new mega sexy shocks to turn up. I have found 2 perfect bumps to do some testing to set these new shocks up on. The first is to a local street with massive speed bumps to set the low-speed compression and rebound on and the second is on those 20mm thick steel road plates with a nice square-edged bump they use to cover road excavations with, to set the high-speed compression damping. That's going to be really good fun sorting that out.
