depends if in your region you still have leaded fuel or unleaded. Unleaded should be slightly brown, black points to a to rich mixture. Check float-hights and other settings on that carb, especially if the choke slider closes completely and the O-Ring at the tip of the choke jet (the looong brass part in the float chamber that reaches into a small hole in the float bowl) is in place and not worn.
