I don't know about the part numbers for replacements but it is fairly unusual the they cannot be resurrected by dismantling and redressing on an oil stone. As long as the surfaces are pretty well flat where they meet, the odd small pit hole is no problem. You will get inundated with advice to fit electronic but the points still do the job for plenty of owners (with Paul Marx at the vanguard).Love..rda said:Hi all, this is my first message, I'm a fresh 750SF '71 owner.
Unfortunately my purchase is not running and the restoration is harder than expected.
Among several reasons, there are the points and they have to be replaced for sure. The original bosch code is 1 237 013 013, but it seems no longer available and reading in this forum someone adapted the Beattle VW.
Now my question: researching for first part of the code is not a matter: 1 237 013 matchs several points, the hard is the last 013... it seems 036 could be suitable, isnt' it?
Do you have any advice?
Thanks
Love..rda said:Well, we have to admit, people who chats about vintage motorcycles says: "Yeah, in the past motors was reliable because no electronic, just a screwdriver and hairpin was enough..." then they buy a vintage motorcycle and the first thing they do is to rig an electronic device up saying: "Yeah now is much more reliable than it was..."
I have other motorcycles more or less the same era, but this I have to admit is a bit hard, yes, my inexperience has a big role, but I hope to come out...
I'll follow your advice and I will start to re-shape these. I will keep you informed about my progresses if it is a plesure for you.
With love..
CLEMTOG said:so did I, probably the same source and the same time, DF and PT?
I have sold most of mine as I don't use my Egli and I still have a couple of sets that I will keep since the electronic ignition does not give enough advance (was pre Phil Todd/Boyer and ex Norton Commando)
With love..
Ah Paul, Is "they" suggesting a majority of owners, some other statistical percentage or perhaps just that unspoken of mob of collector bastards? >Paul Marx said:It is a lot worse than that.
They put electronic ignition on the bikes, say that they're a lot more reliable and then don't ride them.
Shajota said:Ah Paul, Is "they" suggesting a majority of owners, some other statistical percentage or perhaps just that unspoken of mob of collector bastards? >![]()
Perhaps the following wording may apply to some of "they"also?:-
They keep points on their bikes, say that they are more reliable, original and easier to fix and then don?t ride them!!
Anyway, just stirrin' I?m sure there are a lot of bikes in both cases, some probably even very shiny!!!!
Just for interest and to suggest another angle:- I was talking to an old fella that lives round the corner the other day. He is part of the local car restorers club and one of his is a ?49 Ford V8 Ute in beautiful condition. A little while ago he was in the process of putting in an electronic ignition. The ignition was a plug and play item direct from the US which fitted unobtrusively in the distributer. He said it was a very common mod in the US on these V8s as it made them run much smoother, cleaner and was much more mechanically sympathetic. I know, not the same as the twin but interesting non the less. Triple owners would well know the mechanical sympathy plainly evident by installing an updated electronic ignition. Yes, not changing points but a tick for updated technology.
BTW, shed time last night was spent changing a condenser when I noticed a bit more arcing on one side then I would like. (Currently chasing a poor idle so need to check the timing etc anyway - bloody points![]()
