original cable on its way to vendor for replicating and closing out the problem, hopefully updating his catalogue. I shall request that he does.
meanwhile determined that the original spec was 837mm outer, 875mm inner. Speedo end 2,6mm AF square, 11mm projection at rest (vertical, resting on fibre washer in inner). In this position will have 6mm of engagement in speedo giving full engagement (6mm, axial) in drive at gearbox end with 6mm spare. In event inner rides up this spec results in drive being lost at gearbox just before inner bottoms in instrument so presumably preventing damage to speedo internals. Cable needs to be 3,2mm diameter to achieve a formed 2,8mm AF square drive at gearbox end which will work in my 3mm drive, which is I assume worn, perhaps originally 2,9mm or a little smaller. life Will obviously be reduced compared to the original, but i expect good enough for my needs.
The 2,6mm speedo end can be formed from 3,2dia, alternatively can crimp on a 2,6mm tip If you can find one to suit 3,2mm wire. Must exist, but I could only find tips for 3,7mm wire.
another option if wanting to have a good fit in a worn gearbox is to use 3,7mm wire with crimped on 2,6mm tip at speedo and a modified 3,2mm tip at gearbox. carrot cycles (uk) can supply the bits to make your own.
attempted solder repair of original, but just couldn’t stop cable giving up debris to effect a reasonable deposit of material to file to size.
found a couple of uk vendors prepared to make to spec at great prices. Speedograph Richfield and speedycables.
