mauricejota7604
- Victoria Australia
Hi there my RGS based race bike is a smaller engine based on a 77mm bore, it has a number of improvements made in the engine that include a crankshaft rephase to 180 degrees and runs a 3 into 1 and although has been on the dyno with modest results that I wont bore anyone with has consistent power all the way from 2000-8300 no sluggish areas at all to speak of.Maybe I can re-focus the thread and maybe I should have called it "ride impressions" (or similar) so let's not go full 'social media'. It was intended as a comment & discussion thread only to share your experiences. Thanks to those that have contributed their "when does the engine settle in and sing" story.
I've had the 1200 for about 3 years and love it. It came to me with a problem in the cam timing (was a tooth out on the inlet side), it was riden for a while with standard pipes .. and I then went to the 3 - 1. The head has been off because it was obvious that the PO had tried to do it and stopped half way, failing to torque it down correctly and with mis-aligned cam blocks. It's been 6 months (off the road) and the valve timing has been corrected, the ignition changed to Ignitech (because I've had really good results from a digital upgrade on prior bikes). The bike came to me with the Redax triple Mikunis and runs the recommended jets. Aside from that, the engine is standard.
I've taken it out only once since and notice that it still lumbers a little below ~ 3200 (in top gear) aside from that it runs very nicely! This seems perfectly normal with the extractors and bell mouths on the carbs. The K&N filters were taken off because they would rattle off due to a distortion of the rubber). As an example of it's overall performance - if I'm in top gear and want to overtake then I'd better change down (to get the revs up) and then blast by. The bike does sing from 3200 all the way up and is a charm.
As to pilfering others' hard earned data ... be assured that I'm not seeking max. BHP figures or trying to compete in any way but simply keep a good example of the marque on the road. I recall from a older post that there was an optimal diameter for after-market pipes (being 50mm) and as my headers are likley standard diameter but collect to about 65mm when I coupled the collector to the muffler, I settled on 50mm which was it's diameter anyway. The 'out' end is about 10% over the combined exit of 2 standard mufflers. The pipe works fairly well (ride impression only) and as I doubt I will ever get the chance to ride another 1000 / 1200 in my lifetime, why not ask "how does your bike feel"?
Interesting to note that the dyno figures rarely dip into the lower RPM ranges.
So again ... thanks to those that have answered in kind to the original thread. I thought there were a few more triples out there.
What figures did you set your cam timing at.
My 81 Jota has worn a 3 into 1 from time to time and she was never sluggish anywhere in the range.
