Dellortoman
- Tasmania, Australia
OK, being serious for a minute ?
General rules of thumb:
1. Smaller pitch chain will be more efficient than large pitch because of reduced chording or polygon effect (google it). So going from 630 to 530 will make the drive smoother and more efficient.
2. Narrow chain will be more efficient than a wider chain because it's lighter. So going from 530 to 520 will improve efficiency, but sprockets may wear faster because of the higher load on the narrow teeth.
3. Plain unsealed (no-ring) chain is more efficient than O-ring and X-ring chains because the friction between side plates is increased by the sealing rings.
4. X-ring is supposedly an improvement over the older O-ring design, and is thought to be more efficient.
The above is only true of chains in new condition. For knackered chains, who knows?
I use 530 sealed (X-ring or O-ring) chains on my road bikes for longevity. I don't care that they might soak up a couple of horsepower. I still have enough power left to get myself into trouble.
On my race bike I used 530 no-ring for minimal power loss. I could have gone to 520 but sprocket availability was an issue. I didn't want to have to machine the sprockets down to 1/4" thickness. They're not easy to machine.
Valentino Rossi's MotoGP bike uses DID ERV3 520, which is a light weight X-ring chain specifically designed for racing, with low friction sealing rings. Chain life is only 500km max
. I've read that he also uses titanium sprockets which would be strong and light, but beyond the budget of most of us. Although I suspect Jacques might be cruising the internet looking for one now
I'd have thought they'd use a no-ring chain in GP racing, but maybe there's a risk of it not lasting for the full race distance, or perhaps the efficiency dropping off too much as it wears. Motorcycling racing technical journalist Neil Spalding says "The ?No-ring? days, when people were looking for every ?-hp on their RS125s, seems to be just about over".
