Dellortoman
- Tasmania, Australia
I was in the workshop a few minutes ago. The Jota is still on the bike lift with the primary cover off and both chains removed. As I was walking past, I gave the clutch an idle spin and noticed there was no clicking noise. The bike was in neutral at the time, so I stuck it in gear, gave the clutch a spin and the noise was there loud and clear. That indicates to me that the problem doesn't lie in any part of the gearbox that spins when it's in neutral. I assume the countershaft is permanently engaged so that only leaves the final drive end of the main shaft that doesn't spin in neutral.
Furthermore, the number of "clunks" per revolution of the clutch drum varies depending on the gear selected, from about 2 clunks per rev of the clutch in 1st gear to 5 or 6 clunks in 5th gear. That's roughly proportional to the 1st and 5th gear ratios, which is further evidence against the final drive bearing. The prosecution rests its case m'lud.
I've also decided it's more of a solid clunk rather than a light click, and I can actually feel it as I turn the clutch. So probably not just a bunch of un-caged balls flopping about. More likely a totally fucked bearing. I hope it hasn't done anything nasty like spun the outer bearing race in the case, or spread bits of shrapnel through the engine.
I guess I'll find out when I get in there ...
