Dellortoman
- Tasmania, Australia
I think you've invented a new scientific term Piet - specific pressure. Not sure what you mean by that.
For the same spring force, the actual pressure (in psi, kg/m2 or Pa) applied to the friction surfaces of a multi-plate clutch remains the same regardless of how many plates there are. That's one of the advantages of a multi-plate clutch, it's easy to increase the friction area without decreasing the pressure. But you're right about the additional spring preload. An extra friction plate will compress the springs by an additional 3mm. So it's the combined effect of the increased friction surface and spring pressure that stops the thing slipping.
The Laverda clutch must be a pretty marginal design. My Jota clutch started to slip before the plates had worn down to the service limit (thus decreasing the spring force). The one in my RGS engine was re-built with a new set of Red's plates and new springs, 3 of which were heavier than normal. It still couldn't handle the increase in torque that Red built into the engine. There was sufficient room on the splines for the extra plate, so I put one in - problem solved.
Perhaps the next step in the evolution of these engines would be to graft a better clutch onto it. Modern sports bikes are cranking out way more torque than our old Laverdas and their clutches handle it OK with feather-light lever action.
