Laverda SF
That is a great trick Frank. I would guess 4 taps at say 2 - 4 - 8 & 10 o'clock would do it and turn each bolt the same amount to keep the pressure even across the case.
LaverdaIan said:Good comment CK.. didn't know you were into LAVERDA engines though..![]()
8)
chriskay said:The crank bearing looks like it's be whacked in all wrong. The case is buggered! When forced in like that the needle basket is going to be bent, creating a shitty fit. She must have been tight alright, I'd put a new one in and see how it goes. If it won't slide home, or even with a firm hit from your palm, somethings wrong!
