Brett64
- Port Macquarie NSW Australia
Well I ended up double checking the valves and re-checked the gaps, inlet at .15 and the exhaust at .20.
I started her after that and she seemed to idle reasonably well for about 5-10mins then all of sudden she started missing and backfiring and stopping. I left her for 5 mins and then restarted her and she settled down into a good idle and I couldn't hear her miss as before, so let her idle a while longer and tried elevating the revs to 3000rpm and hold her there for a period and all seemed good no loss of power or backfiring....I even put the strobe on her and it seemed good with both the numbers appearing 1 & 2 at the same time and advancing with revs.
So I turned her off and put her back together but when I restarted her she wasn't running as well, this still with the DMC on the 10th curve that I was told to put her on and have been using after using the number 1 position on the DMC.
She started to miss again....this when I decided I have had enough and turned her off and packed up for dinner...the brain is tired.
I am in the process of uploading a youtube video of when I videoed the bike running. when done I will attach the link for you to see and make comment.
Thanks
Brett
Thanks
Brett
