rocketonarail
- Gloucestershire
Lowering links ..... not applicable to the twins and triples I know ....... maybe the Zanes , but I have never delved into the grime ridden , inner chassis neighbourhood of a Nico Bakker , so I would`nt know for sure ......
Anyway , if you wish to lower the ride height of a bike with a linkage set up , you will fit a longer link arm ( aka dogbone in some cases ) .
In order to get my bottom closer to the ground , I have eventually settled on two different , but similar options .............. ..... Lust Racing , and German made TRW / Lucas .......
These two items mimic the dimensions of the factory item they are meant to replace , apart from being longer of course ......... the TRW / Lucas item also comes with TUV approval , just for your peace of mind .
However .......... as part of my earlier endeavours to make better contact with the Earth`s surface , I purchased a USA made Soupy`s lowering link ......
This device has the two bushed eyelets at either end , as you would expect ....... but instead of being cast in one piece , the two eyelets thread into a chunky middle section ..... this middle section is hex in profile .... the idea being that you can adjust the ride height my turning this middle section with a spanner , in the same way you might adjust the height of a gear lever fitted with a linkage rod .......
Once you have found the height you desire , the middle section is secured to the eyelet pieces by tightening a plain locknut at each end .
There were two problems ......
Firstly , although being advertised as a lowering link , with a range of 30 mm , setting the link at it`s longest setting gave a ride height exactly the same as the standard arm ... ( in other words no difference at all ) ......... the 30 mm range only operated from a standard height setting to a height 30 mm HIGHER than standard , not lower ........
Secondly , It was possible to unscrew the middle section completely from the end eyelets ........ So it would be possible for some hapless owner to adjust it to the longest length possible , to try to obtain the lowest ride height .... ( which is the whole point of the thing in the first place ) ....... not realising the engagement between the middle section and the end pieces is relying on perhaps just a couple of thread pitches / turns of the middle section .......
........ and he would then ride off , blatting along at three figure speeds quite happily , unaware that the rear part of his bike ( plus himself ) , is only being supported by a couple of millimetres of thread , and that only being locked into place by a plain locknuts ....... with no guarantee that they would not also work themselves loose at any time as well ........
Needless to say , I soon consigned this item to use as a paperweight , and then eventually dumped it into one of the skips at the local re-cycling centre ........
I was`nt happy to be reminded that this item could eventually be responsible for someone finding the rear of their bike had collapsed , and was now suddenly making contact with the rear tyre at 90 mph ........
A little while back , there were concerns also regarding Aprillia link arms performing a similar quick collapse trick by snapping in the middle .... these were the original fit factory items , not aftermarket parts ............ It seems lack of maintenance / lubrication of the linkage bushes could lead to sudden seizure , and breakage of the link arm ........
Presumably proper lubrication on assembly / change of design / change of use from monkey metal , has fixed that by now ........
