chrisk
- Brisbane, Australia
** We have compressed air and spray guns these times. Blowing paint from the mouth over a hand on rock walls was a good idea in the day. The dancing gals probably loved a man with ochre hands
The auto advance is the part that turns and opens the points. The auto advance cam is what the points and felt pads rub on. Behind the points plate are bob weights that move out with increasing RPM's to advance the ignition timing. If you remove the points plate, what is left behind it is the auto advance. It is held to the shaft coming out of the motor by two screws. You must periodically clean and grease the auto advance or it will wear out! The clip on the end of the shaft in your picture is what holds it all together. Remove the clip and clean and grease it including the bob weight pivot pins. If maintenance is neglected on this part you will eventually have to fit an electronic ignition from it being worn out. If you can feel excessive side play on the cam, it is already worn out.Thanks once again guys- it's hard to tell, but the dirty felt wiper appears to still have some thickness where it presses along the shaft- too bad it can't be removed to replace or clean. I'm sure others have tried this, but I did a search for Bosch ZVUB1Z1Z stamped on the plate, but nothing appears since it's been discontinued.
1200ts- not sure what the "auto advance" looks like- I just see a shaft that the two "blocks" and felt pad press against- please elaborate, thank you.
It's likely the people with points ignitions who're riding.Or just fit an ignition system and forget about it. Always perfectly in tune. Instead of fucking around with irreplaceable and worn out points you could be riding
I have a wind up watch.I see the pointwith going electronic, however I know people who have wind-up wrist watches, a bit like points.
This thread could be sewn together with the BMW wiring and electronics one.
I have several self winding and manual wind watches and they all need routine cleaning and service.I see the pointwith going electronic, however I know people who have wind-up wrist watches, a bit like points.
