If any Lav motor should have major venting dramas, it's the 360 deg SFs, both slugs sucking and blowing in unison. Early (SF1 and prior) had a smaller breather port on the cam cover, so in making the dia bigger the fabbrica must have known it was an issue. I'm hoping that running a 270 crank reduces the fluctuations somewhat but would be interested in an upgrade for the 880 I'm building if it's doable without major hassle.
Not an expert in this, so any advice happily taken on board. Phil, what is the symptom of insufficient venting on a big SF twin? I have blown the gearbox countershaft seal completely out of the motor after a high speed run on very worn rings with the old SF1 small breather!! Oil everywhere ... is this an extreme example of the potential probs?
