AndyW
Hi Cam,
Yes, a mechanic pal with shed up here in the 'ville has a few weeks off work so was interested to help me pull it apart to see what's what. On that basis I put it on a truck heading oop the North. Well, we've pulled it apart and, other than the few obvious symptoms of ill health on display at Bellingen, we haven't found anything really wrong with it. I suspect it was simply shy of crossing into NSW...
Valves look good (though had been running hot): seats look good. A little lapping to ensure a seal looks to be all that is required there. Barrels mic'd up within tolerance, pistons likewise. Will order new rings on Monday from JP Pistons. Head hadn't been torqued down and was essentially loose (though the seal at the flame ring spigots was good). At least one of the shorter 9mm studs had 'pulled' so have ordered a Time-Sert kit to fix that (and others that may be a little suss).
Will hopefully have the head back together by Monday and the barrel/pistons by the end of the week. Assuming a head gasket and shims can be sourced the engine could be back in by end of the month after my help comes back off roster.. So far so good..
AndyW
AndyW
