Hi Piet
Yep, came on straight away, although as I said, my wiring differs from what came with the instructions.
I took the main power feed directly from the battery via a 25A mini relay controlled by a spur off the pilot light. The main feed went to the centre connector of the three way handlebar switch.
I then shortened the wires from the grip heaters. I made up two connecting wires for the high and low settings- spades at the switch end and a double jap bullet socket at the other. I ran a wire to one of the main earth points on the bike and fitted another double bullet socket to the other end so that left me with three double sockets poking out near the fairing mount. I then put bullets on the red (x2), white(x2) and blue(x2) wires and plugged it all in- red to earth, blue to high and white to low (IIRC!). Sounds like a bit of a faff (and it was) but it means no nasty Scotchblocks (or whatever those connector things are called that you clamp over a wire) and of course the grips cannot be switched on if the bike is turned off.
Throttle side:
Clutch side and switch under clutch perch:
I don't have the connectors or crimping tool to deal with those ultra thin wires so I soldered standard 1mm squared wires on to the ends of the thin wires and sealed with adhesive lined heat shrink- you can see this in the photos. I tied up the wiring to a self adhesive cable saddle mount stuck to the inside of the inner fairing.
Cable bundle and relay plate- I soldered black wires on to the ends of the red grip earth wire to match the black earth from the bike:
I didn't like the idea of tapping into a +ve feed directly without a relay- I've got a small plate under the fairing with space for the three relays I've fitted so far to the bike- been meaning to fit one for the horn- might do that before the fairing goes back on.
