G
Grant
Guest
http://auto.howstuffworks.com/question594.htm
http://www.popularmechanics.com/cars/how-to/a3894/4302788/
http://www.tirerack.com/tires/tiretech/techpage.jsp?techid=191
And from Epicenter Design LLC
"Since air contains 78% nitrogen, it has been argued that pure nitrogen has little, if any, advantage over air. However, this argument assumes that the compressed air in our tires is free of moisture, but it is not, as evidenced by the water and oil that must be drained from a compressor's tank. This is of particular importance because as we put heat into a tire, the moisture in the compressed air will cause the air in the tire to expand at a faster rate than a dry gas. Furthermore, water vapor causes the air to expand in a non-linear fashion based on the amount of vapor present, which is usually unknown. Since processed nitrogen is a dry gas, there is no moisture. So, while inflation pressure will still increase with tire temperature, the absence of moisture means there will be less increase in pressure and the increase will be consistent."
