Set the timing on the SF2.
Started by checking the point on the main base plate to see if it needed adjusting. It did, way retarded. So went through the whole process. Started by gapping the points. That done, went to check timing. Nothing happening on main base plate, no current.
Why?
Last year, I'd put new points in and since the felt to lube the advance cam was worn through, I changed the felt for some very flashy orange felt. All was well for a year, about 7 or 8000 km.
The problem today was that having gapped the points, the thicker and more abundant orange felt was stopping the main plate point from closing.
rather than tinker today, I replaced the whole points plate with one I had spare. Before mounting it, I hammered the rivets holding the condensers. One had started to work loose. A proper job would have been to drill the rivets out and bolt the condensers to the back plate which is what I'd done to the previous plate. Couldn't be bothered today, will see to that next winter.
Mounted the new old plate, the points needed filing down and cleaning with acetone after lying around for decades
All's well no.
Needs cleaning, has run all winter without a clean and the carbs need finalising once warm and then off all next weekend for our spring classic rally, down to the seaside in the Somme along minor roads.
