Rear brake foot lever help required
  • Thread starter Thread starter Davo
  • Start date Start date
D
Davo
Guest
I am about to send all my bright bits off to the chromer but note the is a bronze bush in the rear brake lever pivot and it is a pretty tight fit, ie not moving with gentle pressure.
Is it necessary to remove it pre chroming? If so how - I don't want to just whack at it if all I am going to do is destroy it.
Thanks in advance
Dave
Hi Davo,
I had the very same discussion yesterday as I need to replace the bush in my RGS gear lever. The bush is an 'off the shelf' item from bearing suppliers.
It can be pushed out - find a socket that snugly fits the internal diameter of the lever pivot and will face-up against the bush; use a bigger socket on the other end of the lever pivot and clamp the whole lot in a vice; gradually tighten up the vice and the smaller socket will push the bush out into the larger socket. Voila!
I've yet to try it, so can't speak from first-hand experience, but this is how it was explained to me. Let us know how you get on  :D
HTH,
Alan :)
