Dellortoman said:I blame Isaac Newton.
Or the apple ...?
Vince said:I once spent a whole weekend trying to bleed the rear brake on my Pantah after fitting new pads. I tried every trick I could think off. Calliper off and held in the best way. Using reverse bleeding, nothing worked so it went to a pro shop specialising in Ducatis and they fixed it at an eye-watering cost. They said the piston didn't move far enough to clear the tiny return hole. I was a happy boy till the rear brake stopped working heading home. The calliper had fallen off and was dangling below the bike bouncing off the road, luckily it didn't fall into the rear wheel and jamb it. They forgot to tighten the bolts holding it on. Happy it didn't kill me.
Now you mention it Piet, you do have more than a passing resemblance to the classic images of the good lord.sfcpiet said:I attained God status for the weekend! Didn't need to buy any more beer myself, either.![]()
Some others have got 'sexy fingers'! They f@ck everything they touch!Vince said:Magic fingers. It's good to win in front of an audience.
SimonR501 said:Now you mention it Piet, you do have more than a passing resemblance to the classic images of the good lord.![]()
sfcpiet said:Yes, something like that, Mark. As I've broken a couple in my career, I need something a little sturdier, with more metal in it. Fuckin' gravity... :
Jens said:Piet,
this one is solid (also without metal), does its job and does not fall over all the time. You have only have to take care a little bit -> not to kink the hose at the connector to the reservoir after using it many many times. About 90 Euro:
Andre said:I think I've found the problem. Outer 'dust covers' (?) that goes over the little caliper pistons is blown out. Looks like it was leaking only very little fluid out but maybe sucking air inward. Anyway I'm confident a caliper rebuild (or replacement) should fix it.
Thanks for good advice.
Maintenance...
