Going by memory , I think I had all the pistons lined up more or less equally ( 1200 ) ......... As far as compressors are concerned ....... I had a set of coiled expandable ones from Norman Hyde ( Trident Specialist ) ........ USA made ....... Adjusted by a grub screw , in a similar way to a hose / jubilee clip ....... When wound out this screw would separate completely , and of course then fall down into the crankcase mouth , if given the chance ...... Also the compressors would be impossible to remove , once the barrels were lowered down over the pistons , just ending up being stuck between bottom of barrels and crankcase mouth ....... Other compressors may not have offered up these problems .... these particular ones did .......
This was with the engine still in the frame btw , not on a bench .....
Luckily fore saw all this before I tried them ......... Deciding to work with what I had , I just cut back the expandable spring steel of each one so it just covered about 350 degrees of the 360 degree piston circumference , secured with zip ties towards the bottom , below where the rings would be ........... Worked fine ....... zip ties could be just snipped to remove them , and the cut back spring steel could be prised open and removed fairly easily from each piston , before finally lowering the barrels completely .........
( First oversize Asso ? , from Switzerland , I think , originally , now maybe Italy ....... Rings already fitted ..... check gaps are spaced ....... Beautifully finished ..... crown like a CD mirror finish ( flat , not domed obviously ) , and a purple ( Teflon ? ) finish on the sides ........ When I took them to Steve Riley at Piston Broke for measuring up , he said " Ain`t they purr-ty ? " ...... and they were .................... I was thinking of getting a spare one to put on display on a little velvet cushion , with a spotlight trained on it ....... ) .......
