You could, it's possible with caution, if the head is hot enough they'll slide right out but early on before I understood it must be HOT I broke off more than one 6mm bolt using a slide hammer and the special tool bought from Slater and with a tube spacer - heat is your friend in this case.One guy suggested a slide hammer. Could you use a slide hammer after heating it up?
