..me again, been chasing a Toyota 2004 Estima "CVT" transmission problem only at 2000rpm on the road, local service workshop were only making things worse, and not worse in the sense of actually working on the problems, ie making something worse usually means your onto the fault, just the wrong direction. Various tradesman were floundering.
Had ( bought the problem vehicle from a lady owner tired of repair bills that were way to high ), taken me near two weeks to undo the incorrect misleading "repairs" and then concentrate on the actual fault. Easy things first brought marginal improvement, though not convincing. Ordered a set of new plugs, NGK resistor type, grade 6. Well well... its a new motor and no transmission jerking at 2000rpm. Here is the cause, only a 500V megger though you can see it jumps all over the place for a conductivity test, for those not familiar with a hand crank megger, the actual resistance was moving from 1 to 50Meg Ohms a long way from nominal 5K Ohms.
While we may now be using internal resistor plugs, we may well find a new problem to deal with, not so easy to diagnose in certain types of engines.
3 out of the 4 plugs were high impedance centre electrode. Movie to witness. j
