RGA seat repair
Garbrand
Hello everyone. I’ve bought a second-hand RGA seat that needs a bit of repair work.
The front of the seat – the part that rests on the tank – is covered in a soft material. This is presumably intended to prevent the tank from getting scratched.
Is this an original feature, or did a previous owner stick it on themselves? It’s now falling apart due to age, and I’m not sure whether it’s really necessary to replace it. I’m also not sure exactly what sort of material it is.
Does anyone know? Suggestions are welcome.
If the seat itself is in good shape just glue that folded piece back in place and use a thin self adhesive foam sheet where that other piece was put in by the PO. Or better yet, install a tank protector.
So understand that the small piece of thin self-adhesive foam isn’t original.👍
The seat is otherwise in good condition. I’m going to have the rear section near the lock replaced. There are holes in it.
This seat is much more comfortable for my wife, who is much smaller than I am. Now she can see over my shoulder.😉
That’s important, pillions need to know which way to lean - and when. My wife always found it easier to lean to the inside, but on some lower visibility bikes she could be a bit late, leading to a sudden necessity to increase speed mid corner 😁
Misunderstanding. My wife is leaning comfortably against me so that we’re as one, but with the original RGS seat she can’t see what’s ahead. She can only see my shoulder… With the RGA seat, she sits higher up and can now see clearly what’s ahead.
