RGS 1000 marzocchi fork seals size?
parrishsteve
Chicago, IL USA
Hi,
I need to replace my front fork seals on my RGS 1000 w/38mm Marzocchi forks. The parts book says they are size 38x50x7 and use 2 per fork. I ordered fork seals from my North American Laverda parts supplier and I got 2 seals sized 38x50x10.5. I assume then I need to either make spacers for each fork or I simply insert them just below the stopper clip and they should stay put? Any advice?
Thanks and have a great day!
-Steve
I’m interested in this. I understand that some use only one seal with success. I used two per fork when I upgraded mine but there’s quite a lot of stiction, which makes setting up sag etc a bit awkward.
Has anyone had trouble with leaking seals if they only use one?
Does using an emulator of some type reduce the pressure on the seals?
Topical subject. Discussed this over a pie with Ian de lane in Kanmantoo yesterday.
I have run a single seal in each leg on my RGS for quite a while now, to overcome stiction.
I also replaced the valves in the fork caps to reduce the air pressure in the forks under compression, thus giving the seals an easier time.
I also found the the nylon rings on the dampers had swollen over years thus adding to the stiction, fixed by cutting a small amount off the gaps, freeing up movement.
Very happy with the results, nice compliant front suspension.
I will now sit back and wait for others to give their opinion.
I'm with Legs on this. I find one seal is enuf. No leaks. I don't like 'seal stiction' in the forks - as you say, just makes them more difficult to set up and then to get a consistent reaction on the road, ime.
I have also swapped out the original springs and their tubes for a pair of RaceTech springs. There's more than a bit of friction between the original springs and their tubes.
I'm not a sensitive rider, but the difference this made to the bike under trail braking was remarkable.
